Quote:
Originally Posted by Kevin Cullen I also use a rotary on 3400 RPM. I have had no issues with burning. Keep the unit in constant movement and don't hold it on one spot. I always allow the plastic to cool if I need to go over it again. I do not use a wool pad, I use the softest cotton airway buff that I can find. This allows for the buff to stay cool thru the process. Work with the grain of the headlight and it will come out great. There is an example of what I use on my website, click the link below. |
3400 rpm on a
loose cotton buff sounds reasonable to me. Quite safe for lexan and plastics.
Kevin, most on this forum have no clue as to the tools that you are using.
Quote:
Originally Posted by rider9195 The one thing you need to be careful of of the plastic heating up and warping. IMO 3400 RPM is way too high. Start slow and if you need more speed bump it up until the results are achieved. |
Not talking about foam pads or wool pads here. But, in the interest of least aggressive first, then I must concur with rider9195,
if using any variable speed rotary that is
not a Two- Speed like yours.
