Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Ask the Expert featuring Mike Phillips
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 04-15-2012, 02:06 PM   #1
360Detail.com
Kris R's Avatar
Re Spraying Clear Coats
I'm hoping that there will be a few painters on here, or maybe Mike has had some experience with this. But I want to respray the clear of my Jeep. It has some deep bug damage from the previous owners neglect. As you know that sort of damage is permanent. The base coat is perfect however.
I have done a ton of online searching with no avail.
Is it possible to sand down some of the clear and reshoot a few coats? Not removing all of it but just to smooth it out.
Any help would be great.
Thanks
__________________
Kris R
360detail.com
Kris R is offline
Old 04-15-2012, 02:39 PM   #2
BobbyG's Avatar
Re: Re Spraying Clear Coats
Hi Kris,
In a word, yes!
All of the surface defects will need to be sanded or feathered so that it allows the new cleat to be applied uniformly. This is very common and a good painter can fix you right up.
__________________
BobbyG is online now
Old 04-15-2012, 03:56 PM   #3
timaishu's Avatar
I wouldn't recommend doing it yourself unless you really know what you are doing.
I tried on my fender and it worked, but its a very obvious repair. One of these days I am going to remove the fender and redo it.
__________________
Jacob
timaishu is offline
Old 04-15-2012, 08:06 PM   #4
360Detail.com
Kris R's Avatar
I have painted with a gun before and got professional results. I'm very meticulous about my work. See other threads with pics. I've just never attempted this before as far as just re shooting clear.
__________________
Kris R
360detail.com
Kris R is offline
Old 04-15-2012, 08:07 PM   #5
360Detail.com
Kris R's Avatar
Also there is no need to use blender or feather anything because I plan I reshooting ALL the clear.
__________________
Kris R
360detail.com
Kris R is offline
Old 04-15-2012, 08:11 PM   #6
timaishu's Avatar
Wanna come over and shoot my fender?
I tried to feather mine by back taping, but it didn't work, still had a line so I didnt do it right.
Once I become brave enought. Im gonna remove the fender, sand it down and either shoot it myself or see if I can get a body shop to do it. I imagine it wouldnt be too bad if I did the prep myself.
__________________
Jacob
timaishu is offline
Old 04-15-2012, 08:13 PM   #7
It is very possible but like others mentioned it would be a good idea to get it done professionally. To re clear a whole it should be done in a paint booth to get optimum results. Not to mention a good spray gun is very important. Reduces orange peal dramatically.
Agfan is offline
Old 04-15-2012, 08:15 PM   #8
Jacob- a lot of body shops charge you more if you do any work prior to theirs. Although there are some that may let it slide.
Agfan is offline
Old 04-16-2012, 07:42 AM   #9
360Detail.com
Kris R's Avatar
Ok let me clear something up because I don't seem to be getting the responses I'm looking for. I have a very good spray gun. It put out a lot of material and atomizes the clear to leave a smooth non orange peel finish. I also have a garage and fans that I use for painting and don't have issues. I simply want to know if this has been done or can be done since its a considerable shortcut to just repainting the whole thing.
__________________
Kris R
360detail.com
Kris R is offline
Old 04-16-2012, 08:57 AM   #10
Yes ! Why not. After you sand the original clear, the finish should be smooth and the color should be even. Spray on the new clear , wate a couple of days , wet sand with 1500 wet paper, then follow with 2000 paper. Buff with compound and a wool pad , finish with a swirl remover and a foam pad. Wate 30 days polish with a swirl remover again then wax. You should be good to go. Dont forget a good breating system, modern paint has poison in it.
Larry A is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
so i screwed up my clear coat repair, thoughts? timaishu Auto Detailing 101 29 01-12-2012 11:59 AM
Best Swirl Removing Process? F1fan5 Auto Detailing 101 5 12-29-2011 06:53 PM
How can I keep my red cars safe In 100+F Weather!? Teamzambo Ask the Expert featuring Mike Phillips 14 03-17-2011 11:24 PM
Review - Diamondite® Clear Vinyl Kit for Machine Application ehuth1 Auto Detailing 101 11 06-04-2007 05:15 AM
Lifespan of Clear Coats 06CivicSi Auto Detailing 101 7 09-14-2006 08:04 PM
» May 2013
» Car Care Brands
Autogeek.net - We are car care
