» Paypal Bill Me Later | |  | |
05-13-2010, 04:54 PM
#1 | | Member
| Porter Cable XP ?.
Ok, let me start by saying hi to everyone.
I bought my 7424xp back in DEC 09. The machine was running really well for the first two months I'd used it. Around the Feb. time frame my XP seemed to bog under any type of pressure I applied to it. Even under setting six it stopped spinning. Needless to say that I sent it for repair, but the same problem persisted after repair. I contacted Porter Cable again about the issue and they gave me a complete new one.
Now, I have a new XP, and my XP does not spin while it is on setting 1-4. Just the weight of the machine alone bogs it down. Settings 5-6 the machine behaves the way it should. I think. At first I thought I was using too long of an extension cord, so I connected it straight to the wall and I'm still have the same problem. I would like to know if it is user error or what? I bought a Flex while the XP was in repair and I have no problems there. The Flex is amazing, however, I still want my XP to work properly.
Thanks in advance.
05-13-2010, 05:44 PM
#2 | | Senior Member
| Re: Porter Cable XP ?. Quote:
Thanks in advance. | Send it back as I have one and it works flawlessly .You just seemed to have been unlucky to get 2 bad units
__________________ Flex PE 14-2 150,Flex3401,Makita ,Flex3403,603VV and Metabo Rotarys,PC 7336,UDM,PC 7424XP,GG DA, Aztec Hot Rod,VX 5000, CamSpray 1500A and CamSpray Foam cannon.  Ron !!!!! |
05-13-2010, 06:04 PM
#3 | | Member
That is what I was thinking, but I also thought the chance of having to bad units was very rare.
05-13-2010, 06:09 PM
#4 | | Senior Member
anything under sp5 with 6.5' pads and my pc slows or stops.just thought it was normal,now i'm wondering. with 5.5' pads it's not as bad.
05-13-2010, 06:52 PM
#5 | | Moderator
did you install the washer ??
05-13-2010, 07:07 PM
#6 | | Member
Originally Posted by killrwheels@autogeek did you install the washer ?? |
No I did not. I had no idea I suppose to add or install anything on to it. I'll look into it.
05-13-2010, 07:25 PM
#7 | | Junior Member
What???? What washer? Where am I? Who are you? Who am I?
Seriously I did know either can someone share photos?
05-13-2010, 07:41 PM
#8 | | Senior Member
It comes with a washer that goes on the backing plate. |
05-13-2010, 07:55 PM
#9 | | Junior Member
Is this the washer?? Thank you DuBBin1!!!! Almost became trash cause I had no clue and I dont remember reading about it in the instructions... Then again I have problems reading instructions... So said my wife.
05-13-2010, 08:03 PM
#10 | | Member
You guys are great, thanks. Gotta go home and check my box!
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | » Popular Product Links | | | » May 2013 | | S | M | T | W | T | F | S | | 28 | 29 | 30 |
| 1 | » Car Care Brands | | | |
