Go Back   Auto Geek Online Auto Detailing Forum > Detailer's Library > Ask the Expert featuring Mike Phillips
» Paypal Bill Me Later
Reply
Thread Tools Display Modes
Old 01-24-2010, 08:07 AM   #1
360Detail.com
Kris R's Avatar
Wetsanding scratches.....
I searched for wet sanding threads and mostly got orange peel questions.
After practicing on some random junkers with the rotary I find that i risk burning paint trying to eliminate or diminish deep scratches. ESPECIALLY on painted plastic. 2 bumpers at the junkyard I melted a bit of paint using a mild polish, a yellow pad and 1500 rpms with the rotary.
So Im thinking instead of trying to use a rotary for those bad scratches that I would try wetsanding.
I'm wanting to go two routes....Meguiars Unigrit sanding paper (with block?)
OR the 2 inch Backing plate for the DA and using the Trizac discs. I have used those same discs before in a 3M headlight kit. Seems pretty good just dont know if its overkill and I could use just the paper for the same results....
__________________
Kris R
360detail.com
Kris R is offline
Old 01-24-2010, 01:05 PM   #2
O.C.Detailing's Avatar
Re: Wetsanding scratches.....
From what I've been reading, don't use the PC or DA to wetsand as the actual movement of the machine is too big and leaves massive pigtails. I've wetsanded plenty of plastics and use a soft meguiar's sanding block and polished out the sanding marks with my Griot's with much success, though using a rotary is faster. Just make sure you get out all of the sanding marks.
O.C.Detailing is offline
Old 01-24-2010, 01:18 PM   #3
loudog2's Avatar
Megs unigrit w/block. The block helps keep the pressure even.
loudog2 is offline
Old 01-24-2010, 05:38 PM   #4
360Detail.com
Kris R's Avatar
ok. that makes sense...ill give it a go.
__________________
Kris R
360detail.com
Kris R is offline
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Single Stage Paint- issues with scratches 02nissanISR Auto Detailing 101 15 01-25-2013 07:57 PM
What it means to remove swirls, scratches and water spots out of automotive clear coats Mike.Phillips@Autogeek Hot topics and Frequently asked questions 9 01-06-2011 11:19 AM
TOB = Traditional Orbital Buffer aka The Wax Spreader Mike.Phillips@Autogeek Hot topics and Frequently asked questions 1 12-07-2009 08:41 AM
Reappearing scratches Blackthorn One Ask the Expert featuring Mike Phillips 1 09-22-2009 10:08 AM
I would like some help about wetsanding! iMt Show N' Shine 7 11-23-2007 08:10 AM
» May 2013
» Car Care Brands
